Turbo timer not keeping car on
1990_talon
63
Jul 19, 2012
Cranberry twp, Pennsylvania
Does anyone know why my turbo timer will not keep my car running? It works turns on time counts down but as soon as i turn the key the car shuts off but timer counts down.
If I remember right the TT needs 2 separate power feeds. I had to power the TT tot he kick panel fuse block to power the TT while the car was switched off. You need to find a fuse that is powered all the time when the car is switched off. I'm sorry i don't remember what fuse I used but I do remember it was just by the drivers side fuse panel. This is what I used if its a greedy TT. Hope it helps.
1g Wire Colors and Location:
12v - WHITE at Ignition Harness
IGNITION - BLACK/WHITE at Ignition Harness
ACCESSORY - BLUE/BLACK at Ignition Harness
Greddy:
RED - 12v
GREEN - Ignition
BLUE - Accessory
BLACK - Ground
