Apexi turbo timer problem
UrN2nd
75
Mar 13, 2008
friendsville, Tennessee
I have a apexi turbo timer and the inline harness for the 2g. I have the o2 wire tapped into pin 76 at ecu, the ground wire to chassis, and the grey wire to my ebrake wire. Everything works perfectly, except when I lower the ebrake it doesn't abort the timer. If I try to ground the wire manually it still doesn't turn the timer off. It's in the manual mode.
Is your timer a new one or a old one? You know the apex TT is like a 13 year old car part right? And the fact that they're only like 50 bucks now dyas I might just buy a new one, but that's me tho. And really, its only good for being a battery voltage gauge anyhow
It's used. I got it in a big trade of parts and figured IDE try to put it to good use. But u make a very valid point. But the battery voltage thing...... Is it not a good timer?
