turbo timer delete
bowens1414
123
Oct 30, 2012
Bradenton, Florida
well in the process of changing my heater core ive decided to get rid of my non functional apexi turbo timer and the rats nest of wires with it. essentially my question is how should the wires be looking once i pull this, also i have 3 guages, temp with 4 wires to it, boost with two wires and vacuum, and af with two wires and illumination. so of these wires were tied into the 3 ignition wires for the turbo timer. its hell and i need help!
. essentially my question is how should the wires be looking once i pull this.
They should look like clean factory wires that have not been hacked up. With the question answered I will suggest that if you are unable to remove or install a turbo timer, do not go digging in there and clip n cut things. If you must, follow the wires "FROM" the turbo timer and clip each one 3-6 inches "BEFORE" any splice. Do that with each wire coming "From" the timer.
Then put a butt connector on the harness wire you clipped, fold it over like an inch or two and tape the shit out of it. Then repeat with the rest of the wires you clipped. Then wrap all those wires snuggly together once with electrical tape the label it with masking tape "turbo timer".
