turbo swap... now will not turn over?!
dragrush
187
May 1, 2004
North, Louisiana
I tried searchin, but i got lot of random threads, nothing I'm really looking for. Anyways I did a turbo swap and went to go prime the engine, pulled the engine fuse 20a, and when i turned the key nothing happened...the started doesn't even spin. I don't even hear any clicks from interior or engine bay. Before the turbo swap it turned over fine, so I must of accidentally did something that caused this during the swap. The only wire I unplugged (knowingly) was the o2 sensor. Can someone help me out on what it may be....here are things i already checked
Battery- 11.7 volts
Positive to starter- 11.7 volts at starter
Ground to starter
Fuses in engine bay and interior
Any exposed wires or unplugged wire plugs
Any other things to check or tests I can do?
Thanks
