90turbotsi
- 244
- 4
- Sep 15, 2002
Owings Mills,
Maryland
Ok so last weekend my OEM timing belt went up on my 99 with a 6 bolt. The motor had 5-6K on it max. When I pulled it apart I noticed the intake runners were covered in a bit more oil then I expected in such a short time frame. This quickly posed some questons to me. I also when tearing it down noticed oil in my IC pipes (especially around the couplers).
The question is where my oil issue is coming from. I figure on of two places...the head or the turbo.
The head was rebuilt 5-6K ago so I expect it to be pretty set. The turbo was purchased online with "1000 miles on it" its an OEM EVO III 16G. The shaft is tight as expected and I see no oil with the intake pipe off or the J pipe off. (I know just because it has no play does not mean its not leaking out of the seals). The motor has perfect compression, no blow by nothing to make me think its the rings. The breather on the VC is NOT going to the intake pipe, only the PCV goes into the intake tract but clearly to the intake manifold. So I need to figure how the oils getting in the IC pipes, intake manifold and head... I cant help but think its the turbo although being soo new I want to rule this out. I can vouch that I did smell an oil burning scent from the car on occasion BUT NO smoke ever.
Any ideas other then tearing into the turbo? The machine shops going to check out/rebuild the head but how the hell would the head allow oil in the pipes?
Thanks
Thanks
