Turbo-Manifold Gasket
XiKeiyaZI
6,994
88
Dec 28, 2008
Goldsboro, North Carolina
Okay, so I feel this is a noob question, thus I posted it here.
Recently a gasket gave out in my exhaust line. I removed my Exhaust manifold to find scorch marks where it had leaked and blown the gasket which was probably the original one. This gasket, specifically, is the one located between the turbo and exhaust manifold.
Anyway, I ordered an overnight from a local parts store and got a package full of every gasket related to the turbo including 2 I can't identify. I have 2 square gaskets that look like they should go in place of the one that gave out on my car, but one is a solid piece and flat, the other is a 3 piece gasket that is very well manufactured... but the hole is not centered. It's off to one side or the other, depending on how you flip it.
What I'm wondering is... what gasket is this? I looks like the stock one, but the hole is not centered? I have the solid gasket that IS centered but, as noted, it is a solid piece.
Just looking to identify this one. It doesn't look to be a bad machine job, it looks perfect...other than the location of the exhaust hole. Any input would be appreciated.
One more quick question : The new gasket has a lip on it. One side has a hump, the other side has a groove. How should the new Turbo/Manifold gasket lay? Should it lay with the groove up towards the manifold or groove down towards the Turbo?
