G-STowner
- 36
- 0
- Apr 17, 2012
East Bethel,
Minnesota
I am new to the DSM community and I was hoping someone could help me out! If I am wrong about anything correct me because I want to learn. A week or so ago I picked up a 1995 eclipse g-st. anyways, I replaced the CAS, one ignition coil,water pump, timing belt, changed oil and oil filter. the guy before me replaced the head gasket and clutch too. My car has an injen intake pipe and filter, and EVO III td05 turbo, aftermarket recirculated BOV(I'm not even sure what brand it is!),hard intercooler piping, boost gauge and narrowband gauge. now, here is my first question. does anyone know what that little metal tube coming off the BOV is? (look in pics) then my second question is really important. I have only drove it once so far and when I drove it, It was peaking at like 19-20psi when I hit around 6000-6200 rpm. I'm thinking that is way too high too boost without the right parts to back my motor up. So I'm wondering, what do you guys think my boost should be at that would be considered safe? my motor has 180k on it and I don't wanna start breaking stuff. another problem I am having is I am running lean and sometimes I would hit around 4k in second or third gear and the motor would act like it lost spark for a second. noticed my lights were dimming and by the time I got back to my house my car was practically dead. looked at the alternator fuse and it was blown. remembered I accidentally hit the alternator while doing the water pump job and arced it which is I'm sure why it blew. does the loss of power sound like an alternator problem? I thought that's maybe why It seemed like I was losing spark for a second? Also, any thoughts on why I am running lean? unfortunately, I had to leave back to school four hours away so I couldn't even replace the fuse to see how it runs! I know this is a lot to answer and I thought about making two threads but I thought it would help for you too know all my symptoms. thank you!
