Turbo finally GONE!!!
Mitsu RacerX
2,821
4
Feb 25, 2006
On the beach, Mississippi
Well my turbo finally cuaght the ghost. So I'm going to order a Big 16G with a FMIC. Do I need to get bigger injectors or will the old ones work. I'm just looking to get a little more power out of the car, no drag racing. Alos will the fuel pump support the new turbo. I was laos looking into getting DSMLINK....Thanks :D
If your getting dsmlink then I would get bigger injectors because you can compensate (sp) for them. If you don't have anything to adjust your fuel (dsmlink, safc) then don't get bigger injectors.
A bigger fuel pump is recommended. A walbro 190 should be good, if your not looking for crazy power.
At the very least, rewire your stock fuel pump with thicker wire (if you havent already)
