turbo feed line leak
d-meeks
53
Aug 17, 2011
burlington, Wisconsin
hi guys my turbo feed ling leaks the guy i bought the car from didnt do a every good job and i was wondering what i need to replace it becasue it have the evobig 16g turbo in it a link with what i need excultly would help alot
thanks Dillon
Wheres it leaking first. If its leaking at the head from being stripped out you could heli coil it or just jb weld it. If its from the turbo you will have to drill it and tap it depending on how bad it is. They make lots of fittings that will make this an easy repair and look nicer. If the hose is leaking you could hit up a speed store and get some compression fittings and fix it.
the guy i got it from conected 2 houses so i just want to replace it wil one house with new fittings so i was wondering what size hose and fittings and stuff i would need
