DSMJim
- 3,328
- 41
- Jul 24, 2002
kpt4321 said:Whaaaaattt??
Have you ever looked at your intake temps? Did you read the posts where other people showed the temperature difference?
My intake temps get over 100 degrees all the time, even when ambient is only 60 or 70. A cold air intake would give me ambient intake air. 70 is cooler than 100.
I understand that 100 deg is hotter than 70, thanks. No where have I stated that it's not going to make power. I just am not sure if that 30 deg cooler air before being compressed by the turbo is going to translate into a faster 1/4 mile time on my car. Lets assume the air going into the turbo is colder and colder coming out based on your experience. How much HP did you gain? Doing runs at the track is not really great proof because how fast your run is all depends your launch shifting etc etc.. Too many variables. THe only way I can prove it to myself is to see a repeated gain in performance at the track on my car. I don't know why that is such a problem for you that I just don't take your word for it. Is this insulting to you or what?
I never said it doesn't work, I said only that it's a pretty small mod and small difference so the gain is going to be small so I'm not sure it's going to be worth it or not. Were not debating the effectivness of nitrous or 35psi. Those are obvious huge gains in power. A cold air intake is not a huge gain in power, sorry.
WTF?
A temperature gauge saying that the conditions are colder is not good enough proof? What the hell do you want, an average molecular sped analysis?
I could care a less what your temperature gauge says on your car. That does not translate into faster 1/4 times on my car. Just because YOU say it, does not make it gospel. I prove if things work or not by doing it on my own car. I have found a lot of things didn't work that people say do, and a lot of things do work that other say will not.
So you have to test everything on your car, before you know it works?
Do you run nitrous? Water injection? Propane injection? 35 psi? If you don't run one of those, I guess we can't say it works until you do.
Yes when were talking about something that is debatable if it helps or not (because it may not help my car) were talking about 15-30 deg cooler air only. I may gain 3hp and have absolutly no change in my 1/4 mile time YOU have no idea what is going to happen on my car.
Argueing about Nitrous, water injection, propane, 35psi is stupid. Those are obvious HUGE gains in hp. Were not talking about a huge HP gain here.
I don't know why your getting all upset. It's a cold air intake, really who cares? How much difference could it possibly make? I'm I going to get a 75hp increase? Not likely. Were talking about such a small gain here that it's not even worth debating. Debating small HP gains is for guys with slow cars, not a group of guys who are used to 50hp gains from a single mod and are still not satisified with that.
My next mod right now is finishing up my AEM install hoping to pick up 30-40hp from the stand alone's ability to fine tune my setup. My next mod is going to be pistons and rods in a 1G swap so I can spray 75hp shot ontop of boost. Those are mods that give HP gains. Bothering with a cold air intake is hardly high on my list of things to worry about. Like I said I may mess around with it to see if it helps however I'm not all excited about a 3-5hp gain. Whoptie do.
Lets all relax and chill out on this subject before this gets locked. There is no reason to fight over a stupid cold air intake.
