- 11,533
- 29
- Apr 8, 2002
Chandler,
Arizona
Liquid Illusion said:How about you show me some *real data* that proves it makes no difference.
None of the fastest dsm'ers I've heard of use one?
clownface said:what about like going through a big puddle really fast when your not paying attention or something? would that get it wet enough for it to suck in the water?
Beh. A T-25 pumps the air out at over 200°F. Ten degrees at its inlet won't be making enough difference for the bother. And although the motor won't care about injested water in small amounts, droplets impinging on the turbine blades is bad. Very bad.Liquid Illusion said:How about you show me some *real data* that proves it makes no difference.
Fact:
Lower lnlet temps yields a more agressive timing advance across the board.
Fact:
Lower inlet temps reduces the onset of pre-ignition at any boost level.
Fact:
Lower inlet temps yields lower charged air temps post turbo and I/C
And the best spot for the filter would be right on the turbo??...if your on blow through of course.
L2RTSiAWD said:None of the fastest dsm'ers I've heard of use one?
Fact:
Fact:
Fact:
Fact:
Fact:
Fact:
ItsStockOfficer said:Apparently my post was ignored, I have made over 60 passes in the 1/8 mile on the same setup with this being the only difference, I can't run 7's wiouth cold air, and its about 1 MPH difference in the 1/8...89 to 90 MPH consistently, with reasonable variation, but its very consistent, and of course since I have numerous datalogs showing that it reduces knock and increase timing, it does make sense.
The idea that an intercooler cools all air to a given temperature regardless of inlet temp is the stupidest thing I have ever heard.
ITSME4G63 said:Make me one, right now! get to it!
L2RTSiAWD said:If you have a efficient intercooler it shouldn't matter where the filter is located.
DSMJim said:I completly agree on all these counts but still am not totally convinced that a cold air intake on a turbo car will give you any colder air.
I think a properly sized intercooler to your application is much more effective way to acheive those three goals then a cold air is.
It seems to me like a cold air would work, but I have yet to see some solid proof really. People seeing cooler air temp inlets on their DSM link isn't really proof to me personally.
Not that I am disputing that but I like to prove things to myself on my own car in my own controled circumstances. If it makes a repeated gain then I know it works on my car.
DSMJim said:You have no idea if it will work on my car at all, neither do I.
