turbo and turbo psi ?
Status
Not open for further replies.
talonman2011
Banned Member
20
Jan 30, 2011
listowel, ON, Canada
Ok frist question is i have a 95 talon tsi in the morning when i go for coffee LOL and the car is just starting to worm up.I can get 12 psi out of my turbo. But when the car is to temp it will only boost to 7 to 8 psi. I chack for boost leaks and nothing all good there what would couse this problem.
Question 2 I was reading on here about how to tell if your turbo is going bad
and one menber said if you take off the intake boot off the trubo and see oil there it needs new seals. Is this true. I have a little puddle of oil there about the size of a dime and i will clean it up and few days later look again and its there again.Is this normal and if not could this be the problem with question one.
The Oil is produced from your PCV which should be (and I'm giving you the benefit here) routed from your valve cover to the intake snorkel. This 'Blow By' can include oil deposits which can often be found in engines as a small smudgy lining along the bottom of piping, turbos, and couplers. From the sound of this, I would say that you are 'okay' but you may want to perform a compression test/leakdown test.
As far as the falling boost level, I want to simply state that I don't personally ever get into boost with my engine cold. As the engine warms, things expand and take up space...say...piston rings? That Blowby that you have is caused by compression getting past the rings and into your crankcase. Now say that your 'boosting' before the engine is at OT is allowing boost into your crankcase, this could be a POSSIBLE reason for your oil deposits in your intake piping.
As for the boost falling, Warm Air = Less Dense than Cold air. That turbo warms up quite a bit after it's been functioning for a while.
We warned you about your grammar in Feb. If you do not make an effort, we'll handle it on our end.
You and your grammer your starting to piss me off about it. I asked a question spelt everything right and it was answered thank you XiKeiyaZI. But u and your grammer like take a hike. I still dont no what your talking about. I think it was wrote out fine and it got answered so he must have not had a problem reading it. Sorry where all not collage grads and have perfect grammer and sorry spell chack dont chack grammer or maybe its just you dont no how to read so go bug someone else on there grammer
kick me off the site what else is new i just open new account and post again
Spell check will find "chack", "grammer", and "spelt". "No" is not "know".
Did you know you broke a second rule by challenging a mod? No, you didn't, since you can't follow the grammAr rule, despite agreeing to our terms of use.
Ban recommended since you did this same crap 2 weeks ago.
Sign up for a different forum, you won't be returning here.
Status
