turbine exhaust stud
Your nearest mitsu dealer is a good bet.
I had to buy all new bolts and studs for my manifold and turbo.
They aren't cheap because they are "heat treated" said the dealer.I already know the turbo and manifold gets hot and strips the threads especally with the vibrations from the engine and exhaust.Oh well, so far so good.
Thanks bud Im goin to go chech that 2morrow:thumb:
You can order from here as well if you're not in a terrible hurry.
http://www.extremepsi.com/store/customer/product.php?productid=17633&cat=864&page=2
I purchased mine from a local store that carries every type of bolt, nut, screw imaginable. Took my old ones in, told the guy what I needed and what it was for. He came back with a set...paid like $4 each.
Check your phonebook for listings named for example..."City Bolt Supply" or "Rochester Screw"
I purchase mine from a local store that carries every type of bolt, nut, screw imaginable. Took my old ones in, told the guy what I needed and what it was for. He came back with a set...paid like $4 each.
Thanks bud, but I dont need them. I need the one stud that is on the turbine housing, its part of the o2 housing bolts. The one you put a nut on, not the 3 bolts. I need that stud:rocks:
The mitsu dealer should have plenty in stock. Get it from them and you won't have to wait for delivery like you would if you decided to buy one online.:thumb:
sorta related, what size are the studs and nuts that bolt to the O2 housing installing my Downpipe i cross threaded the nut and well now i'm leaking fumes.
M10 x 1.50.
That stud is removable. A good pair of vise grips can get it out. Most peole I know (myself included) end up removing that stud and replacing it with a bolt. It makes subsequent manifold removals that much easier.
He's talking about the turbine to o2 stud, not manifold to turbine.
Correct, but a bolt could be used there if you really wanted to, just would need to make sure it wasn't too long to ride up onto the O2 sensor.
Thanks oldman!:dsm:
Thanks oldman!:dsm:
Silly me. Yeah you'll need the stud. A bolt won't even get in there to fit. Dealer's the best place to go.
