tuning suggestions??
btracer
187
Oct 21, 2002
reading, Pennsylvania
i need some advice on what type of tuning setup i should go with. i currently have the following mods...
fresh motor, removed balance shafts w/ 9.1:1 ross pistons
HK$ 272 i/e cams
ported/polished cyclone intake
slowboy 20g ported/clipped
apexi FMIC
2g maf (removed honeycombs)
550's
HK$ 45mm external wastegate
greddy type r bov
wideband
ATR 3" exhaust... etc etc etc 360awhp @18lbs
car is currently tuned with reprogrammed ecu and SAFC and HKS evc II boost controller
i really want to get a logger and post up a few 3rd gear pulls, but until then i was just curious as to what you guys would recommend me getting for optimum tuning.
thanx
When you say "reprogrammed," do you mean a chip that has injector compensation?
I'm not sure what more you could ask for besides a 1G dsmlink... That is a pretty good setup besides the lack of a datalogger. You have a wideband, you must know something... I'm confused.
~Mark
yea it just has the chip, and i know how to tune the car as it is now but i just wanted some opinions and maybe some comparissons to other peoples setups. i have low counts of knock and no timing problems, but i want to have more adjustability. the 1g dsmlink is one of the options ive been considering, as well as the EMS. just wanted to hear what you guys had to say before i spend the loot :cool:
If you're going to stay with that setup, get custom timing and fuel maps and bigger injectors.
If you're going to go with 1g DSMLink or EMS... well, go for it. What's there to be said about those systems has probably already been said.
