ECMlink WOT Tuning Pull Advise or Suggestions
Rock2610d
255
4
Jan 22, 2013
Cheyenne, Wyoming
Well, finally did a 3rd gear, WOT, pull from 2400 rpm to 5850 rpm. My boosest does not match my omni 3 bar MAP.
MAFRaw tops out at about 1200 hz no more..
Any suggestions?
thanks
I wouldn't worry too much about the BoostEst not lining up, especially past 5500-6000 RPM. You've got your wideband and AFRatioEst lined up pretty darn well.
I'd say crank up the boost, see how things respond, and then start adding more timing in until you see knock. I see your last pull ends around 18* timing, so you may not have much further to go. Everything looks to be dialed in well.
