ECMlink wot log please advise
motozachl
1,251
24
Jul 15, 2008
Jacksonville, Ohio
Boostest is dead on
aem is off by 3 or so doesn't match the gauge reading ever although its logged to the rear o2 sensor
.4 knock is that bad?
airfuelest seems extremely lean?
I got my idle and cruise dialed in really good although my mafcomp was about 35% was this ok? the combft was around 0% while the airflowperrev was right at .25
note I am using ecmlink with v2.5 chip
mods: 1g head \\ 264-272 cams \\ 2g 7bolt \\ 97cas \\ ported 16g \\ pte 880s \\ dsmlink v2.5 \\ wally 190 rewired \\ ported 2g manifold \\ ported o2 \\ full 3" exhaust
Take a look at your wideband, make sure there is no leaks when you install it. Make sure you all cables connected and look for loose cable. Your wideband did not give you feedback at WOT. .04 knock is fine. if you have. zeros all your fuel setting, correct me if im wrong, your global should be -49.4% and deadtime 330 or 345. because i have the same injectors.
