Tuning help needed... 2.3 stroker
Jaydog
44
Jan 26, 2011
grand rapids, Michigan
I am new to tuning have Ecmlink V3 and need some help getting my tune right. Here is a log.
Running through your log it looks like you're running .30-.32 gm/rev. Have you done the whole maf comp adjustment?
Log the ISC position , learned idle adjustment, and check the base timing- it looks a little high. The base timing with the ECU grounded is supposed to be 5 degrees. Also, find out why the throttle is sticking.
Other than that it looks like your on the right path.....take it for a cruise and get a log.
You need to change your load factor to 87% (LoadScale tab in DA tables), but overall that log looks pretty good.
Don't get too hung up on AirFlowPerRev; it will vary quite a bit from the numbers you typically see posted depending on your setup. If you are sure your fuel settings are correct, you can just watch your fuel trims and dial them in with MAFComp (or VE table) and injector deadtime.
