General TunerPro question regarding Boost/MAP readings
Havoch
5+ Year Contributor
48
5
Apr 15, 2019
Mission, BC, Canada
So, just curious if anyone knows how to edit the .adx file so the boost readings can be corrected. I have come to find that the values shown on the dashboard are not copacetic with my boost gauge and when adjusting cells for timing, fuel, etc.... I can't rely on the log value and have to extrapolate as to what the boost gauge is reading at the same time. Annoying.
The stock boost gauge in the dash isnt a real gauge so there's no way to make them line up.
lasthope05, not referring to stock boost gauge. thats just crazy talk.
Make sure your Map sensor is scaled properly would be a start...if the xdf/bin is set up for a 3bar and you have a 4bar...
I don't know if it is "scaled" properly but my MAP scalar is set to 70.31%. The .bin is set up for 3 bar map and i am using a GM 3 bar map.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
