Trying to trace wires...
IceDragon
547
Jul 13, 2004
Gilbertsville, Pennsylvania
Where does pin 1 wire on the camangle sensor come from??? I know it is supposed to be getting 4.8-5.2 volts and only gets 3.73-3.76 volts. I replaced the ecu, I replaced the crank angle... so what else is between the two!?!?!
so you say that pin 1 and pin 2 on the crankshaft match up directly with pin 1 and pin 2 on the N/T ecu?
No, I said that pins 1 and 2 on the CAS run directly to the ECU as far as I can tell. That would be pin 22 and 21 on the ECU.
This is for the turbo cars but 99% is the same for the 2.0L N/T cars too.
http://simon.chi.il.us/~steve/Auto/DSM/1GDSMWiring.html
Steve
