2G Trunk Doesn't Completely Shut
Eclips3_4_Lif3
Jul 13, 2016
Fort Worth, Texas
The trunk of my 2G doesn't work entirely right. I usually have to pump the release lever twice because the left side gets stuck, and when shutting it, the right side doesn't seal all the way. What could the issue be?
Being that you have two different spoilers on your car, it is probable that the hatch has been removed and/or replaced at some point. You may just have a simple alignment issue which can be corrected by adjusting the hinges at the top.
I'll definitely look into that. Thanks for the advice
