420A Transmission problem - Broken Bellhousing
Rigoberto
Aug 24, 2019
El Cajon, California
is it okay to put this transmission back in? Or should I buy a new one instead? It came off when I got the transmission off and I saw the crack when I was unbolting it as well.
I would at least buy a new belhousing.
That chunk missing will allow dust, dirt, critters, fluids etc to get on/near your clutch which is not good. That would also affect your torque. Having a missing belhousing bolt is not the best idea.
clean all the oil, grease and dirt from that half of the bellhousing, inside and out. then find somebody that tig welds aluminum. i'm fairly sure it can be re-attached
Yea I did what he said I bought some JB weld and put it back just letting it dry now
That is a structural bolt hole. I think you're wasting your time. If you have no other option I guess you have nothing to lose. If you ever run into this again there are other structural metal adhesives that would have been better options.
What other adhesive should I use? The piece was able to move so I just took it off
It's been 20 years since I did any. Fish around here or the like.
Years ago I did a spray adhesive with a catalyzed activator. Just as a test I glued a 2 inch fender washer onto a piece of steel angle. I put it in a vise and hit it 20 times with a 2 lb sledge hammer before I was able to knock the washer off. Google around and I'm sure you'll find something. Your parts will need to be clean clean clean.
Having it welded is the best option. I’ve used quiksteel on my buddy’s cracked exhaust manifold and it held up for about a year. He sold the car so don’t know how it held up after that.
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
