Transmission noise
XSNRGGST
159
May 26, 2007
Tucson, Arizona
I searched for this thread that I thought I read recently. I don't have a lot of time to go through all the threads with a fine toothed comb.
I thought that recently somebody recommended that new synchros for 4th and 5th gear might help with some tranny noises in those respective gears. It could have been a recommendation for some new bearings as well. All-in-all, it was recommended to purchase a couple of $20 parts instead of a whole new transmision. I am asking for a refresher on this thread, or at least the part numbers for the parts in question.
I recently asked about my own transmission challenges in another Thread entitled "tranny noise" in the newbie section.
I have a 97 GST with 122k. I have recently been experiencing some new noise when I am in gear in 3rd, 4th, and 5th. It seems to be a growling/grinding and is only present when I am in gear and am keeping a load in said gears. When I let off the thottle/coast in those gears, there is no noise. There is no real problem shifting otherwise and the tranny shifts well at all other times. This noise seems to be the only pressing matter in the scheme of things. There are no other performance issues/drivetrain problems.
I recently changed out my motor mounts, thinking this may be a problem, but it still exists.
I do have a broken inner driver's side CV boot that has been this way for a liitle while now. It is in decent shape with only the very outside of the smaller part of the boot torn from the clamp. There is still grease present on the spider gear which I have felt with my finger. Could this be causing the noise? Or is it definately a tranny issue?
I will definately be planning to replace the whole axle very soon with a replacement from Checker/AutoParts America.
Thank you very much for your help in this matter.
EAC
It could be the clutch disc or throw out bearing. Maybe even possibly the input shaft. Usually tranmission noises will give you some kind of driveability problem such as gears grinding or the shifter popping out of a gear.
Why dont you try putting your car up on a hoist and run it through those gears. Have a couple friends underneath listening for the noise. Before you start buying parts and spending a fortune make sure you know you are going to be fixing the problem. Get any dirt etc in that CV axle and it will make a nasty noise after time. Even if there is grease present.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
