Transmission mount replacement?
SAME HERE its easy if you know what you're doing but i got by,by unbolting it from the body, first, taking out the front and rear trans mounts and that gave me enough room to pull the trans mount on the right side out.
Are you changing to polly mounts? If yes, you must change all four mounts. If no, make sure the other three is still in near perfect shape.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
