Transmission internal swap to new bell housing help!
Kyogie12
306
Feb 14, 2010
Boulder, Colorado
Hey all, I had a quick question for those of you who've played with the internals of our transmissions before.
So I have two FWD transmissions, I want to take the internals of one (all good, the bell housing is just cracked in a few places and can't be fixed easy), and put them into another FWD tranny I have where the 3rd gear syncro is bad, but the bell housing is awesome.
I was wondering if I need a press if I was just going to swap the internals, and if there would be a way then to not have to remove any of the gears/syncros from the shafts?
Would it just be easier to try and sell them both and pick up a used FWD tranny?
Thanks!
You don't need a press if you just swap gear stacks (and the rest) into the same generation FWD tranny housing. However you should measure/adjust shafts preload and end play. Here's what you'll be swapping:
No I can do that later today. Check the serials that is. I do believe they are both from a 95. But i'll have to double check. I'm just trying to figure out the best option for fixing that 3rd gear syncro for the least amount of money.
95-96 trans are the same and the 97-98 are the same so make sure u get the same 2ga trans before attemping. Ive rebuilt a the 95 trans 3 times and honestly they are pretty easy. Once youve taken it apart (hard part) pretty simple to put back together. Being your first time taking one apart I would suggest u take lots of pictures.
