transmission help asap
1990gsx1781
190
Jun 28, 2008
Lynn, Massachusetts
i was looking threw old threads and didnt see anything so here it is and if its been covered before sorry. i just bought another gsx its still a 90' but the tranny grinds in 3rd i was told that a 91 or 92 doesnt match up that you have to mod some stuff if this is true what do you have to do thank you. also i dont have the tranny to my old gsx anymore so i cant swap =(
Well, It's sorta true... The 1991-94 trans will work but the output shaft to the transfer case has a different number of splines on it (23 whereas a '90's is 22). You either need to mate it to the proper transfer case or swap out the output shaft.
Well, It's sorta true... The 1991-94 trans will work but the output shaft to the transfer case has a different number of splines on it. You either need to mate it to the proper transfer case or swap out the output shaft.
LOL so if i just grab the same t case to mate with the 91-94 tranny that will work right sorry for the dumb question sorry for the stupid question transmissions are no where near my area haha
the 91-94 tranny will require 91-94 shifter cables and bracket on tranny for the cable
Ideally, Yes... But the cables are not needed, if you're in a pinch you can make the '90's cables work with some crafty adjustments.
The 1991-94 Gear Selecter Bracket (the one that can be removed w/2 bolts).
The Bracket that holds the cables to the trans.
