transmission dead go 6 bolt?
jdombrow
130
Nov 13, 2008
Escanaba, Michigan
alright, swapped out fluid in trans a few days ago because of a strange sound from tranny. came out a little thicker than water milky white and full of flakes. i have damage to all gears and will pretty much need to rebuild and replace everything in the tranny.
heres my issue. I can either get the transmission rebuilt or should i buy a 1g 6bolt and do a full swap. im assuming i cant use a 95 transmission on a 6 bolt block so any suggestions?
Im mainly worried about the engine crankwalking, if it does am i able to rebuild it and not have to worry about it ever crankwalking again? or would i be better off rebuilding the engine now before it crankwalks to avoid future problems?
any info's appreciated.
Exactly what Snowborder said. You can only use a 2g tranny.
Its probably easier to just replace your tranny than to go ahead with a 6bolt swap.
But thats totally your call.
oh awesome, i didnt think a 6 bolt would match up with the tranny from a 7 bolt, thanks alot everyone, are there any places with reasonable prices for trans parts if im going to do it myself? i checked teamrip but im going to need all 5 new gears along with synchros and everything it adds up fast.
You should fill out your vehicle profile, so we can help you better.
I would suggest getting a transmission form Sheptrans.com
Stage 1 = $945 + core
Shims for setting preload
New Nylon Shifter Pad
New Center Diff Side Shims
New End Nuts
New Roll Pins
New Intermediate Gear Bearings
New Input Shaft Bearings
New Input, Output, and both Drive Shaft Seals
New 1-2-3-4 Synchro Springs
New 5th Gear Synchro Rings
New 3-4 Synchro Rings
New 1-2 Hub/Sleeve kit with Double Synchro Rings
New Shep Trans Spec 2nd Gear
New 3-4 Fork
New 1-2 Fork
New engine dowels
To be honest, just roll with a knowledgeable tranny builder.
Yea, they make a little bit, but it's done right so you don't have to pull it all apart later.
If you have the money...a budget 6 bolt buildup would set you for a nice receipe.
Is your car stock now? If so, just put a tranny in it and drive it.
