Resolved Transmission Bolts
mark 91 tsi
30
Jul 31, 2011
Inver Grove Heights, Minnesota
I am removing my transmission on my 91 Talon TSI. I have removed 4 bolts between the motor and the transmission and the bolt from the transmission mount. I looked online and found a bolt kit from JZN Tuning that shows 5 bolts. I cannot find a fifth, very short bolt, but I can not get the transmission to come free. I just don't want to pull too hard and strip or snap something. Here are the four bolts Y removed between the block and transmission. Please let me know if I missed anything or if it is just time to pull and pry. Thanks.
There is a small bolt that enters the transmission from the back side thru the block! If I'm not mistaken it may be thru the dowelpin area, but I know its back there! I had the same issue many years ago pulling my first trans! Good luck
1Gs have 4 "main" bolts holding the block and transmission together. 2Gs have 5 "main" bolts. That could account for the difference on the site you checked. It looks like you have those 4 out for your car.
There are a couple other bolts that go to the transmission, not necessarily for holding the transmission and block together, but will catch you up: one goes through the starter plate on the front side; the other(s) are on the lower flywheel inspection plate. Make sure you get those out as well.
If it is an automatic transmission, you need to unbolt the drive plate from the oil pump by removing the inspection plate and turning the motor by hand to get to all the bolts.
  • Wanted 1g 6 bolt rear timing cover tins both sides.
    6 boltRear timing cover tins.
    • Robert503
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted 2g WTB: 2G Eclipse GSX / Talon TSi AWD (1995-1999)
    Looking to buy a 1995-99 AWD Eclipse GSX or Talon TSi — running or project, rust-free bones...
    • Total Eclips3
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
