flywheel bolts
robs93gsx
Dec 2, 2010
post scandales, Idaho
Hres a way newb question but does any know what size the flywheel bolts are on the 1g awd :D
I went through my whole socket set and could find one that fit it tight its 19mm right
You're asking for the socket size? Lol oh...
It's either 17 or 19... I'm thinking 19, but I mean did you try a 19 and it didn't work or something? What's the actual issue you have?
How much is a little?
I'm 85% its a 19 ... try the 19 and if it starts to slip/strip then stop. Are you using a 6 or 12 pt socket?
I have had a few that started to round when removing. Impact gun is really needed sometimes, and makes things much easier. Otherwise heat the bolts up and use a breaker bar if that's all you got. Just watch what you are doing.
