Resolved Flywheel Bolts Question
Tom Gibbons
50
4
Mar 22, 2015
Beecher, Illinois
I'm installing a new clutch and Streetlite XACT flywheel. I torqued the 6 bolt flywheel bolts to spec and realized i forgot to put loctite on them. So I removed them, applied it, and re-torqued the bolts. My question is are these bolts (brand new OEM Mitsubishi from STM) stretch bolts? Can they be torqued to spec, and then removed and re-torqued without issue?
Thanks for the confirmation guys. Peace of mind is always good to have. Did you use red or blue Loctite? I personally went with blue.
And one more question, are the torque specs different for the pressure plate bolts if I am using an aluminum flywheel? I planned on doing 168 In-lbs
