transmission bolts question
toppertopper
444
May 14, 2009
edmonton, AB, Canada
Finally after a month..I tracked down an awd transmission to put in ..Tossed it in tonight..Thought i marked all my bolts but i was wrong
The pic shows the bolts i am unsure of and where a starter bolt fit ..i thought one of the 12mm bolts went there ..Yes i did check vfaq's pic
thats a 2g and looks nothing like mine ... if it did u.u are starter bolts uy are the same as the 2 top bolts ...a u fits in where q is suppose to bit but q is to small and wont thread in there
The hole with the rear dowel is what the 12mm head bolt goes thru. It goes thru the block and into the transmission.
If it didn't relate to your situation, I wouldn't give you the information. It actually looks very close to what you have and the transmission bolts are the same size/location on a 1G. You've also got to read what was supplied for you as all the technicalities are covered.
There's this, too, but it's not as pretty: http://www.dsmtuners.com/forums/drivetrain-tech/308808-transmission-bolt-sizes.html
The starter bolts are longer than the 2 top transmission bolts, at 60 mm long.
ROFL wow i must be tired , i was looking at the transmission wrong
..I see where q goes and the bolt i have miss placed at the top ... I fail :ohdamn: :D 6 am wake up to get it together in the morning ...Been awhile since i've drove a dsm ... :D oooo the excitement...THANKS again everyone
