transfercase fluid????
shawny2087
75
Apr 15, 2005
milwaukee, Wisconsin
im ready to put oil in my tranny/transfer case and could not get redline anywhere around here so i would have to order so i got 3 qts of 75w90 mobil one syn. gear oil for the tranny but what can i use in the transfer case? can i use the same stuff???
Put the Mobil1 gear lube in the transfer case and abosolutely do not use it in your transmission.
"DO NOT USE Mobil Sythetic gear oil or ANY oil that meets GL-5 specifications or poor shifting will result."
That's straight from Jon Ripple at TRE.
Pennzoil Syncromesh, GM Syncromesh (same product as Pennzoil) B&G Syncroshift 1 or 2 are good alternatives to Redline in your tranny.
Mobil1 gear oil works great in the transfer case.
i agree. i changed my trans fluid and used Lucas synthetic and now it grinds gears. i ordered BG Syncroshift from MachV which you can also use in your transfer case. they give you 3 quarts which is enough to do trans and transfer case. i thnk it was around $49.00 not including shipping.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
  • Wanted wtb black 2g dashboard
    Looking to buy a 2g black dashboard. Located in southern california but willing to travel.
    • randizzle420
