Transfer Case/Driveshaft alignment
Xenocide
37
Sep 2, 2004
Madison, Wisconsin
I've been troubleshooting a drivetrain problem and have been trying to tweak the drive shaft and tonight I through an angle finder on the drive shaft and it is within 1/2 a degree all the way across the board, however the transfer case is tilted down as if the front of the engine is high and the back is low so it's the open end is pointing more towards the ground than straight toward the rear diff. Any suggestions on what I can do to resolve this? The motor mounts look good. The DS should be good I just spent the $300 to rebuild it w/ all new joints and carrier bearings. Problem is vibration whenever coasting.
