trans. fluid soaked clutch? bad or worse??
red98gst
119
Jun 9, 2003
E-Town, Kentucky
My differential exploded and sent a piece through the case and it leaked fluid onto the clutch.. I know for a fact that it got to the disk because it slips because after it broke it started slipping really bad.. Is the disk ruined or can I clean it off. I do not want to TRY putting it back in without knowing for sure.. It is a spec stage 3 4-puck clutch
The friction disc is ruined. You can dick around with it and try to clean it with brake cleaner or the like, but it'll never be "right". You'll be bucks up to replace it.
