2G Trans cooler relocation
Ive done several for people like this. On 1g and 2g. My personal car is done this way
And here is mine
Heres the kit you want
Brackets are easy. Go by some 1/8x1 aluminum flat strap. I keep it on hand here for all kinds of brackets. Measure, cut to length and drill some holes in it.
If you were close id help you but every car is a bit different
OK I'll look into it, also with the lines from the factory cooler, do I just run a new line from the original bottom line to the new port of thw cooler and do the same with the top one as well?
Yes all lines will be replaced. These are your new trans fittings on top of trans
This is my setup. Basically the same that @enriquez2000 has done minus the AN lines. :thumb:
Do you have pics of how you mounted it, or used?
It is held in place with HD zipties to the flat area just above it (the hoses would almost hold them). I drilled 2 holes for each cooler (I actually run 3 sandwiched together), then used electric fan mounts to push thru them so they are all one unit as mounted to the car and I used the intercooler duct to channel air right to it. I also used some aluminum up front to make sure it got good cool air.
Both lines will need to go to your new cooler.
Sorry if I confused you. So from the transmission there's a line that goes all the way to the cooler. Then there's another line from the transmission that goes to a nipple on the bottom of the radiator, then from the other nipple there's another line that goes to the cooler
You will bypass the nipples altogether. 2g used the radiator to try and help cool trans fluid. You will no longer be using that.
Didnt mean to be short before I was driving.
Juat take the lines from trans to new cooler and block off those nipples
