tranny or clutch
Arcangel2501
47
Jul 26, 2012
Okc, Oklahoma
ok heres the deal i have 1999 gsx with a performance head and force performance turno upgrate and injectors ect made over 450whp when driving it normal it shift ok i change it from a act 2600 to a spec stage 3 plus and its still doing it when i shift at high rpms it wont go into 2nd gear from first i miss it every time and every once in awhile it will go in but most of the time it will miss it what do you guys think ? the clutch is rate for 500ft/tq and when i launch it. it slips ever time when i have someone in the car with me
i put a new slave cylinder new master cylinder im at a lost
will find the problem my input shaft is leaking tranny fluid all over my clutch well look like i will be tearing into my transmission grate
Yay for leaky input shaft seals! :|
That sucks after having done the clutch already. I had the same thing happen. :sosad: At least the transmissions in these cars don't weigh 400lbs and are relatively easy to get out.
Have you shimmed the pivot ball? That will make a big difference in clutch fork travel. Also if its at high rpm that you're having trouble shifting your clutch disk may be too heavy. They're hard to drive with but an unsprung 4 Puck is your best option for an easy to shift trans.
He really shouldn't need to shim the pivot ball unless the fork sits about halfway or towards the passenger side in the window on the housing. The fork position should be slightly towards the drivers side when the slave rod is touching the fork and touching the pressure plate fingers. If it's not then there could be something else wrong like the step height is wrong, disk thickness is too big, fork is bent, pivot ball or socket is worn, clutch fingers pulled in too far.
If step height is correct, disk thickness is good, pressure plate fingers angle slightly away from disk when installed, fork isn't bent, and the pivot ball isn't worn then you should consider shimming the pivot ball to get it in the correct position in the fork window.
So you're saying an unsprung puck clutch is the easiest on the transmission in regards to shifting?...
