tranny froze
95gsxNw
Jan 26, 2011
modesto, California
I just bought a 95 gsx with 140k. the guy told me the clutch was somewhat new but it was slipping. i can care less about the clutch so i bought the car. on the way to my house it seemd like it was getting harder to put it into gear(i didnt think about it tho). the next day i went to drive it to kregens but i couldnt get it into gear, at all, nuthin, 1st 2nd 3rd 4th... reverse just grinded.
So my question is, what could the problem be and what do i have to fix.
no clutch pedel is fine. i took out the clutch pedel sensor also so i dnt need to put it down to start it.
could be a throw out bearing. if its a puck clutch a spring could have popped off. I was going to say master slave cylinder, but usually when that happens the clutch pedel sticks to the ground.
There's been a rash of this lately. Here's what you check in-order.
Low hydraulic fluid (never gets low unless you HAVE a leak somewhere).
air in the clutch lines.
Leaking clutch hydraulics (watch the ETCG Clutch hydraulics video on YouTube)
Loose transmission bolts. There are 7 of them, and 4 little ones that don't matter on a clutch cover plate.
Preloaded clutch master cylinder from improper clutch adjustment at the pedal.
Failing rubber clutch line
a bent clutch pedal assembly.
Broken clutch fork
fragged clutch disc.
If the clutch is slipping and all of the above are verified to be correct...
Pressure plate bolts are loose.
Alright, thanks for the help. Im ###### gonna get a whole new clutch set up neways, i just wanted to make sure i didnt buy a messd up tranny nd whatnot.
on another note what is your oppinion on the ACT 2600 clutch kit. pros, cons everything helps
  • For sale 4G63 Frontline Fabrication V2 Billet Valve Cover
    Frontline Fabrication V2 Billet Valve Cover $750 + shipping & paypal fees* swivel AN fittings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
