Car froze overnight
HyperGSX
1,167
Oct 10, 2002
Schaumburg, Illinois
The fuel froze last night since it was like -10 degrees and I had just a tiny bit of gas in the car. Its supposed to be 17 degrees tomorrow, I dont know if that will be warm enough to unfreeze. Is there any additives I can add that will help this process?
Fuel doesn't freeze.. but water does.
During the winter mos add DryDas (2/$.99 at most gas stations) to your tank ever couple fillups.
If you have frozen water in the fuel line this wil prol not help.. but will help rid you of any that is left in the tank.
Rubbing alcohol will do the same for drying water in fuel. Available anywhere at anytime. 1 bottle /15 gal fuel. If you look at the active ingediant in fuel dryers, it is usually isopropyl alcohol (rubbing alcohol)
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
