Batt. Died Overnight?
JayB12
544
Jan 12, 2009
Philipsburg, Pennsylvania
Ok, so I just got a new gst, I brought it home and parked it. the next day I went to start it and it had a lot of trouble turning over, but it started and was fine. Now I tried to start it today and it wont even click, my interior lights go out when I turn the key and I have a volt gauge that shows my batt. is dead now. It had a full charge when I got it and I believe that the alt. is working well. The car has a lot of electrical stuff and an aftermarket alarm. Why would the car just loose the charge? Nothing is on that I can see.
You need to hook up a tester to the battery to show if there is a current draw somewhere that isn't supposed to happen.
battery could be bad. sometimes they end up with bad cells and just discharge themselves. the hubby's did that. i hooked it up to the tester at work and watched that sucker drop .1v one by one. and you figure over a couple hours, that adds up to a lot of volts gone :\ and that was with nothing hooked up to it.
The alternator also could be dragging it down mine was doing that and after testing the battery it was the alternator and DSMS are notorious for bad alts. I would really recommend just puting a 96-97 galant ls alternator on it anyways even if it is not the alt it give out more volts fits perfectly and lasts longer. and it oculd be the alarm mine was doing that and i had to have it re installe for some reason. hope all works out.
So I called the previous owner today and he thinks he knows why the battery is dead. The headlight was broken when I bought the car and I repaced it and the wreck that broke th headlight knocked the sensor that tells if the hood is shut down somewhere and I don't know what it looks like or where it shold be mounted. Can anyone verify that this could cause the problem? If so can I get anybody to post a picture of where this sensor mounts and what it looks like? Thanks.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
