chrisman287
5+ Year Contributor
- 1,158
- 1,110
- Jul 19, 2021
New York
So maybe I’m doing something wrong here but this is driving me crazy
I have a 1G N/T TB on my 6 bolt swapped 2G using the 2G TPS. I usually adjust the TPS after unbolting the TB and loosening the throttle cable. It’ll be at .63 then after I start the car and turn it off and check again it’ll be .7x-ish
I pulled the fuel rail and grinded down a 1/4 drive 5/16 bit to turn it into a thin walled socket so that I could leave the TB bolted to the mani and adjust the TPS while it’s all together. Again the same thing happened where it was at .63 and after I start the car and turn it off and check again and it’s at .71
I’m trying not to use the TPS offset in link
