torque converter
diamondsm
107
Mar 27, 2010
port orchard, Washington
K so I have a 95 tsi awd auto that im replacing the torque converter on..
So I went and orderd it today from autozone but they had two kinds one that came with a. (Rear cover speed sensor) and one that did not? I orderd the one with out but im not sure if I orderd the right one they did not have the option to put in that it was awd so could I have the wrong one? I really need to know the part take 3 days to get here and I don't wanna have to take it back and wate longer.
if anyone could help please do
You should of had them order both and return the one that doesn't look right. I would of highly considered going to a transmission shop or having your existing converter rebuilt. Why exactly are you replacing the converter?
Im replacing it because it would not move in any gear I pull a tranny line and had no presure.....I was going to order both but because autozone didn't cary the part I had to pay up front I looked at the online pictures and the looked the same between mine and bothe that autozone had
One reason there are two versons of the torque converter listed is because there are two different versions of the flexplate that the converter bolts to. One is stepped out from the motor further than the other. I recommend taking the VIN number off of your car and calling the dealership so they can give you the OEM part number. Have autozone cross reference the OEM part number to make sure that is the correct converter you ordered. If autozone can't cross reference the number then cancel your order and go to a parts store that can. Good luck!
