topline gasket kit
n2orbit
298
May 10, 2003
just wondering if its worth a damn. i have the 4 layer headgasket. but im putting my motor back together and was wondering if the other gaskets in the overhaul kit are good or bad.. i should be making over 400hp running the fp3052 if that helps any or should i buy a oem kit i think somone had it for 259 bux.. also if anyone knows where i can get it cheaper... or a better gasket kit. and about topline.. thanks guys
it probably isnt a bad head gasket but if you are going to be pushing 400 horses then i wouldnt risk it
98TsiAWD said:
I used the Topline gasket kit, And I dont have one single leak!
Did your kit only come with gaskets, or did you do overhaul your motor? I am asking because My 91 Tsi needs an overhaul and I am looking for a good quality kit. 310.95 seems pretty cheap to me for everything that is included in their "major engine kit" Does anyone have any suggestions for engine repair kits? My tsi is going to be a daily driver with basic performance, no upgraded internals.
I am rebuilding mine engine right now as well. I got the complete OEM gasket kit from Josh that used to work at Concelli Mitsubishi for. The Company is JNZ. The number is 1-215-631-1224. I can't remember how much it was, but I paid under 200.00 for it. I am thinking 180.00. It had everything.
