too much brake pedal play
Aznspice27
93
Oct 28, 2008
Riverdale, New York
hey guys well i just finished changing my brake pads... i bled the brake lines and i started the car...OH SNAP i didnt pump the brake before i started the car :banghead: now when i started driving the brake pedal goes all the way to the floor and i have to pump the brake 3 or 4 times before it starts grabbing... can anyone help me with my problem
thanx
Check your brake fluid level. If it went too low when you bled the brakes, chances are you have air in the lines.
one of my friends told me i had to pump the brake before i turned the car on and i didnt do that.... i have major air in my lines... i unbolted the brake line and let it drip out a bit checking the brake fluid level.... i added more once i was done.... i pumped the brake pedal and it sounded like it was sucking it up good... i had to put a whole another bottle of brake fluid... i turned the car on and it still has a lot of play.... i literally have to pump it a few times to start grabbing while im driving..
You dont crack the brake line to bleed the brakes. There is a little bleeder valve on the caliper, have a freind pump the breaks a few times and then push the pedal as hard as he can and hold it down. As he holds down the pedal, crack the bleeder valve open and close it while your freind keeps pressure on the pedal, some air and fluid should spit out of the valve. Repeat the process until just fluid and no air come out. That will fix your problem
You need to do more research befor attempting to do jobs like this to save your self wasted time and effort.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
