told me to check the timing and crankshaft and cam shaft sensor
streetlegalboi
Aug 7, 2007
tucson, Arizona
i got a obd 2 scanner.. and it told me to check the timing and crankshaft and cam shaft sensor... soo i order the two... can someone tell me the location for these two sensors?? i got a 420a engine... rs model 98... thank you in advance
The camshaft angle sensor is on the head, on the driver's side, nearest to the front of the car. It's a flat sensor, held in with two bolts.
The crankshaft position sensor is held in with a single bolt, and is about 2"-3" above and to the right of the oil filter housing.
Really should get a car manual.. it helped me a ton!!! Look up the names of the index and bam right to a page where it tells you location and how to remove and replace it :D
Funny you own a scanner but no overhaul manual.
i have a book haynes.. but the picture sucks... soo i needed better info.. ty much guys!!!
