TSiWarrior
- 300
- 10
- Feb 17, 2005
Detroit,
Michigan
My car is toasting clutches left and right. I know how to drive a manual quite well and I havent been horribly abusing my clutch. I've had the trans off twice in the last 2 weeks trying to figure this out. I've checked the slave and master, both are fine. I've closely checked the flywheel and it looks flat as glass with no heat char. So far i've toasted a 6 puck, a stock clutch, and 2 autozone clutches in about a month. I've only launched the car maybe 6 times total. There seems to be no oil leaking, no loose bolts, pressure plate fingers are even, slave isnt putting pressure on the fork. I cant figure this out. I've tryed just about every ajustment you can think of, I've put the car in fwd mode, pretty much everything. The previous owner said he was having bad luck toasting clutches so he put the 6 puck in, the 6 puck lasted about 600 miles before the metal/ceramic shatterd off of it. The engine block has no cracks, the trans is bolted tightly.
Any ideas whats causing this and how I can fix it?
