To4e turbo what size injectors?
nosaj531
Nov 9, 2005
Loveland, Colorado
I am putting a TO4E Turbo on my 1990 FWD Laser RS was wondering what size injectors to go with. I am also running a Safc and a MAF Translator not sure if that matters at this point or not and i also did the rewire with a relay on the stock fuel pump. Which is my next question will i need a 190 or a 255 fuel pump or will the stock pump work with it hard wired?
TO4E is the designation for the compressor cover, which doesn't really tell us anything. Is it a mitsu garrett hybrid, t3/t4 hybrid, or T4? What size wheels does it have? What size turbine housing does it have?
go ahead and get the 255 :rocks:
give me pics of your turbo...hit me up on aim again if you have ?'s :thumb:
turbo pic .50 .70 gattett stage 5 wheel i believe
Thats not a to4e, it looks like a to4s. The compressor cover is slightly larger than the to4e and might give you some clearance problems at the water pipe. Find out what compressor wheel it has in it. What manifold are you using?
I agree. The t04e has a .60 a/r and a 3" inlet. The pic posted has a .70a/r and a 4" inlet.
Regardless, the compressor cover has nothing to do with the size of the turbo. Remove the compressor cover and measure the inducer and exducer of the compressor wheel. Then we will have some useful info for you.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
