Resolved Timing side motor mount bracket torque specs
Kvkenamond
42
17
Feb 14, 2022
Los alamos, New Mexico
I've been staring at my factory service manual for hours now and can't seem to find the torque specs for these bolts and this nut anywhere. Hoping somebody can help me out.
Hate to revive an old thread but it seems a fitting addition to a resolved thread on torque specs. The FSM calls for sealant on the lower BOLT on the bracket but does not specify other than a rough sketch. Could we get verification that it is the bottom one and that it is the only bolt/fastener that requires sealant? It looks as though it could be the middle bolt, however. Screenshot for reference.
By the looks of the screenshot you’ve shared, it would appear to only be the one bolt indicated by the arrow.
However, I’ve noted in threads of old that both lower bolts should use sealant. May have been a case of, “It’s better to have sealant and not need it than need sealant and not have it.” See second picture here.
On a 2g only the middle bolt requires the use of a thread sealant as the FSM states. The 2g has 3 bolts and one stud. The center bolt is the one.
Picture for reference. It was junkyard block with no head attached which why you see the rust.
-Daniel
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
