Resolved Driver side motor mount to block torque
DeNoZZo
685
Jul 6, 2008
Waterloo, Iowa
Can anyone tell me the torque spec to tighten my driver side motor mount down to the block? I searched but couldn't find it.
Thanks!
Just snug it down, it's not critical. The only thing I torque at work is wheels, cylinder heads, and calipers that mount into aluminum knuckles.
Yea that's what I was thinking. I just wanted to make sure. I definitely have more than you listed torqued to spec though. I've heard too many stories of critical bolts backing out.
Nuts/bolt on top: 49 ft.lbs.
Bolt through side: 72-87 ft.lbs.
*EDIT*
- thanks turbosax!
It is always a good idea to do things the RIGHT way!
I agree, but that doesn't mean I have comebacks due to something not being tightened to spec. Over time you get a good feel for what things need 10-20ft lbs, 30-50, and 60+ up. Believe it or not but a 6"inch long basic ratchet can tighten to 90ftlbs without hurting yourself/ really heaving on it.
There is the 100% by the book way which covers every little detail and maybe on my own car I'll follow the procedure. When it comes to work - doing things by the book doesn't make you efficient - wasting time on torquing every little nut and bolt to spec. and following unnecessary steps.
If you tighten something, yet your worried about it backing off - you either think things need to be incredibly tight, or you need to put down your purse and tighten it up - and I don't mean putting your weight on the ratchet/wrench.
I guess it's easier understood once you are in the industry for some time.
  • Wanted 6 bolt NT water pipe
    • chrisman287
