1G Timing Belt Tensioner Washer?
thetech0922
111
Oct 26, 2010
Piedmont, South Carolina
Ok stupid question: Timing belt tensioner..I bought OME parts for my timing belt kit. Both pulleys, belt, auto-tensioner, and the cylinder the pushes on the auto-tensioner. Bolted it all back up but my auto-tensioner is dragging?? I put a washer behind it that fit the bolt perfectly and it spins without any issues. Here is a picture of what i am talking about. 1 is where i put the washer behind :confused:
I'll have to look and see if I still have the original washer on the mount I replaced (the tensioner arm pivot wore out) and if so measure it's thickness.
Edit: Turns out I misread the diagram in CAPS and there isn't a washer behind the tensioner pulley. Are you sure you have the right tensioner pulley? There is a difference between the 1G (MD129355) and 2G (MD182537) ones.
Yeah i never put a washer behind my 6-bolt tensioner pulley, it just sits flat aginst the the Tensioner Arm..Then the bolt is put through with a washer on the bolt (on top of the tensioner pulley) and torqued to 40 ft lbs..
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
