Timing Belt Snapped, Rebuilding Engine Input
shiftdrift06
257
4
Jan 10, 2005
Houston, Texas
Hey everyone, well my belt just snapped. I might have bent valves and damaged pistons. I am kinda releived because I can stop procrastinating and finally rebuild my engine. Which had low compression in Cylinder 1 and @180 in the others. It had an oil leak (I think its the head, maybe need to trim that one headbolt). Anyways I was looking on HowellAutomotives and CI, and wasnt sure how I should go about this. I tell you guys what I want/have in mind, and you guys can tell me what I could get/setup.
On a budget!
Plan to go turbo (was actually in middle of pieceing together kit)
Daily Driver, only gonna run about @10psi
Perhaps bigger displacement
I am open to any part suggestions (pistons, rods, crank, valvetrain, misc parts..ect)
You wont know whether or not the cylinders need to be bored out until you have the motor apart and the cylinder "miked" for out of round or taper. Once you know if they are in spec or not then you can go about ordering pistions. If you must bore the motor you will not be able to actually bore it till you have the correct pistons ordered. The machine shop will need the pistons to accuratly bore the block to meet the required piston to cylinder wall clearance.
When you change pistons you will also need the rotating assy balanced too.
Terry
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
