reavis_99
- 0
- Nov 16, 2012
Harrisburg,
Illinois
So, here I go... I have a 2003 Galant ES 2.4L Its timing belt snapped at 80,000 miles and I figured I bent the valves. I took the head off and had it inspected by the local machine shop; they said it was fine(no bent valves). I do have spots on the pistons where the valves had made contact. I bought a new timing kit and replaced everything: belt, tensioners, etc. The old belt was at the bottom of the belt cover wrapped around the crank cog (by the CPS). So, I put everything back together and started the car. To my surprise, it started rough and the exhaust manifold started to turn cherry red after running for a few minutes. It revs up very slowly as if it has no power, I cant even drive the car it is so bad. Do you believe the machine shop made a mistake and I have bent exhaust valves, or do you think it could be another issue? I also pulled the exhaust manifold and started the car... to my surprise, fire came out as if the exhaust valves were open when it was firing the cylinders (Im assuming out of time possibly). Please help me, I am at a loss.
Could the balance shaft be out by 180 degrees causing this issue? I have read that on another forum. I am going to tear into it this weekend again and just wanted some advice. This is my first Mitsubishi car.
Thanks
Thanks
